What is everyone seeing for top end RPM's with the new 1.9L's? mine seem to top out at around 7300 right now. wondering what everyone else is seeing and if I need to check a few things if i'm low.
@jcb1977
According to boattest.com they got 7800 WOT on the 252 they tested. I had an issue with low RPM a few years ago and had to adjust the throttle cable. I followed the video from @JetBoatPilot
@jcb1977
I looked at the weather data from a few days ago from your location to get the altimeter setting and dew point / relative humidity for a 75° day.
You can see from the chart below that your 800’ above mean sea level (MSL) on that day was actually 2194’ as far as the engine was concerned, looks like a hp loss of 2.2% or 4.4 hp per engine. In my opinion not enough to account for a 500 rpm loss but still something to be considered.
Note: I saw a Berkeley Jet Hp demand curve a couple of years ago that showed for that particular pump the hp required to spin that pump at 5000 rpm was 375 hp, to spin the same pump at 6000 rpm required 735 hp. So you can see there is an exponential rise in hp demand as the pump reaches peak performance.
Thats great you are using non ethanol fuel, usually premium is 91-93 octane. I’d check your owners manual to verify the following, the normally aspirated engines usually require 86 octane. Contrary to some popular beliefs 91 octane does not have more power than 86 octane, in fact if 91 octane is used in an engine that only requires 86 octane that engine will produce less power and run hotter than it would if using 86 octane, because the 91 octane burns slower than the 86 at the lower cylinder pressure of a normally aspirated engine versus the higher cylinder pressure of the super charged engine that requires the 91. In addition you are also spending more money on fuel than you need to.
I run non ethanol fuel as well, but I mix 85 and 91 in the correct proportions to get 86.
I use this calculator. Octane Mixture Calculator
If you do not have access to 85 or 87 non ethanol you can run ethanol fuel just be sure and use Star Tron at each fill up to make sure the ethanol fuel doesn’t get phase separation. I will run ethanol fuel if that is all that is available at a destination I’m at then run all of that out once I get back home and re fill with non ethanol.
Per my manual 87 with 10% ethanol is totally fine to run, which is what I put in my two 1.8s without issue. However I always fill it at the end of season with premium non-ethanol and treat to lower the chance of water absorption.
