local
- DFW, TX
When I bought my boat last year I, as usual, did some research. Before I could request the dealer replace the old plastic scupper they informed me that they had already done so, with another plastic one. I told them that I would prefer they had installed a stainless version and surprisingly they agreed and replaced the one they had just installed. Mission accomplished!
While using the boat last year I noticed the bilge ran more often that I thought it should. My previous boat had a rotten transom and let a constant 1/4" stream of water in the boat so I really didn't think much of the bilge running every half hour or so otherwise I might have noticed it earlier.
So now I believe that I have a small leak and since I will be taking my boat to the coast next month today I decided to investigate the leak. I go out on the water and stick a borescope down the access ports in the cleanout tray. After a few minutes I found two leaks. One on the thru hull part of the scupper and one on the hose connection of the scupper.
I get the boat home a little frustrated since I had that replaced so I wouldn't have to deal with it and considered going back to the dealer with it but decided it wasn't worth the hassle. After opening up the back and gaining access to the scupper I found the nut was completely loose, I hand tightened it half a turn. The house clamp on the house was in the wrong place and was crushing the hose before the scupper housing.
My question now it since I am this far in should I go ahead and pull the scupper to reseal it to the hull? Should I attempt to find a replacement hose since the end is somewhat damaged from the incorrectly installed hose clamp? Or should I just put some RTV on the hose and install it correctly then seal up the inside of the thru hull fitting and not try to pull the valve out?
