Stand up is 300lbs. Maybe I’m border line over the 550lb rating, but I can move the boat back a few inches. This is a common set up on the jet ski forums.Gotta agree. With due respect...that's a sketchy setup.
That standup has to be at least 500lbs. alone. There goes your tongue weight.
Doesn't make it a good one, just a popular one. Kinda like elections, popular does not equal qualified.Stand up is 300lbs. Maybe I’m border line over the 550lb rating, but I can move the boat back a few inches. This is a common set up on the jet ski forums.
You're taking the wrong perspective of my previous post. I see it this way: "Because many people have done it, the set up has been extensively tested." I'm going to break down my logic.Doesn't make it a good one, just a popular one. Kinda like elections, popular does not equal qualified.
Not sure why everyone keeps accepting "because everyone else does it, it must be a good idea" when the risk to persons and property is this high?
I think the way you think about it makes a lot of sense, for example using “moment of force” rather than static weight is probably more appropriate to consider dynamic loads on the receiver while trailering.You're taking the wrong perspective of my previous post. I see it this way: "Because many people have done it, the set up has been extensively tested." I'm going to break down my logic.
Let's ignore the idea that there is a jet ski on the hitch and examine the physics of it. Increasing the tongue length will result in a higher moment (M=F*D) on the receiver. Maybe i'm increasing by a factor of 4 because the distance is increased approximately 4x. There isn't a specified rating at how much moment a receiver can take, but I have friends that are 30+ years professional welders/fabricators that wouldn't hesitate to do this.
Let's consider the tongue weight of the trailer. Nothing has changed because the trailer doesn't care what's pulling it. Shorelander recommends a 6% tongue weight. My google search shows the AR192 weighs 3000 fully loaded on the trailer. 3000lbs*.06=180lbs. No problem, maybe that is what it is now.
So going back to the truck's tongue weight rating. I load the AR192 and adjust it according to the 6% shorelander rule. It weighs 180lbs. Then I attach the hauler (it's surprisingly light - 20lbs?) and the jet ski 300lbs. 300+20+180=500lbs. I'm borderline at my truck's rating, but the ratings are usually conservative and I feel confident.
The final factor is the load on the vehicle's suspension. The rear is sagging a little bit once it's fully loaded, people, and gear. Definitely don't want the rear of the vehicle squatting because that has adverse impact on the handling. I will install air bags to pump it up a little.
Maybe not everyone agrees with me, but I have thought about the physics of everything. I was an auto mechanic, welder, fabricator, engineer, and I have a background in many different powersports. If you don't agree with my logic, please counter my logic.
It won't be an exponential increase because the formula is M=F*D, so the force is directly proportional to the distance. There could be legal challenges, but I will only do this set up a few times and won't go on highways with it. I live about 15 minutes from the ramp and it's all stop-and-go driving. Also, it's likely that the boat will be parked 2 minutes from the ramp. If I build enough confidence, maybe I will try the set up and bring it to Lake George (4 hour drive). I guess this was an important point that I should bring up in previous replies. I was just excited to defend myself because I over think and over engineer everything.I think the way you think about it makes a lot of sense, for example using “moment of force” rather than static weight is probably more appropriate to consider dynamic loads on the receiver while trailering.
That’s said you are far from being within legal limits with that setup, make no mistake about it.
For one, increasing the receiver length 4-fold does not automatically imply momentum goes up the same way, it could be exponential, not to mention also need to consider sway forces - that long receiver can jackknife your car and trailer before you know it.
Bottom line, you are exposing yourself to legal challenges that you are not likely to win if something bad were to happen. We all hope and pray nothing bad will happen to us but once in a while we’re glad if we have the insurance and happen to operate within legal limits. That’s all.
Well, not to argue... But... it will be exponential.It won't be an exponential increase because the formula is M=F*D, so the force is directly proportional to the distance.
Oh hey another Okie.Try again.
I think you are confusing D (aerodynamic drag), with d (distance).Well, not to argue... But... it will be exponential.
Because at highway speeds you generate turbulence and aerodynamic drag force which is proportional to the square of velocity...
And it’s a real force, too, no bs.
Sorry, I had to.
Thank you for the extended hitch calcs. From the page:Apparently there's a difference between an extra long ball mount and a hitch extension?
Effect on Hitch Tongue Weight Capacity from Use of Hitch Extension | etrailer.com
Plus this: How to Figure Weight Capacity When Using a Hitch Extender or Extra Long Ball Mount | etrailer.com
"One thing to note when using a hitch extender like the Hidden Hitch, # 80307, is that the the tongue weight and towing capacity of your trailer hitch will be reduced by 50 percent due to the increased leverage that is placed on your trailer hitch from your trailer."
That's with an 8" extension.
Try this: Extended Hitch Calc
Roll those dice brother...hope nobody gets hurt.
No.I think you are confusing D (aerodynamic drag), with d (distance).
Moment=Force x Distance
Drag = coefficient x ((density x velocity squared)/2) x reference area
In which the drag shouldn't change before and after the added jet ski. Everything in the above formula stays constant.
Help me understand... By your own calculations, given the shortest extender available (8") halves the tongue ratings, you could not legally tow the combo, right?Please keep your snide remark and let's have academic discussion.
Effect on Hitch Tongue Weight Capacity from Use of Hitch Extension | etrailer.comSo going back to the truck's tongue weight rating. I load the AR192 and adjust it according to the 6% shorelander rule. It weighs 180lbs. Then I attach the hauler (it's surprisingly light - 20lbs?) and the jet ski 300lbs. 300+20+180=500lbs. I'm borderline at my truck's rating, but the ratings are usually conservative and I feel confident.
I don't think so.If anything, this conversation will help others see the mechanics of hitch extensions. It's the added moments on the receiver that reduce the tongue weight rating.
This is a valid point.I don't think so.
Notwithstanding the silliness of having an academic discussion of something that involves an illegal practice (of operating a complex machine at highway speeds) let me cut to what I'm trying to say:
It is not the strength of hitch/hitch extender limiting the safety ratings here; rather, it is stability of the entire combo moving down the road.
The power of aerodynamic drag is impressive. One does not need to boat trailer on a highway to experience that power - if you ever launch in high crosswinds you will know the feeling. On the highway, gusts of wind of the passing of big rigs can cause trailer sway. Even with regular/short hitch (and no WDH or sway bars) that can be a handful.
While increasing tongue weight is a typical remedy, it does not work with a hitch extender due to added leverage. The bottom line: hitch extender is not the weak point here (albeit it can be), it is the tail wagging the dog phenomenon (the whole thing).
That's just my 0.02.
Over and out.
