Solenoid valve advice needed
buckbuck
Texas
I want to control the factory ballast bags separately (212X) by placing solenoid valves after the ballast pump, allowing me to lean the boat when I surf. I seem to recall someone (Cam?) saying you need a special type.
Anyone have insight on this? Will a typical 12vdc Asco solenoid valve do the trick?
Sorry but it wont work. Well it will but only in one direction. Been there and tested all alternatives. What you need to use is a electric ball valve. The 12V chinese brass ones are available on ebay for cheap with free shipping usually. Hope this helps. I am putting in 2 this year. Cam.
ps make sure it is a full-port 1" valve with NPT threads. You are better to use a slightly larger valve (ie 1" on a 3/4" line) to reduce any flow losses.
OK. Thanks Cam. I'll find some and post back for your thoughts on what I find.
I will have a look and recommend some. The only true difference is that they come with about 4 or 5 possible wiring diagrams. They all work but the one to use is the 12v power to open, then spring close. I will post some info. Its too bad that the regular solenoid valve don't work for us. I tested the 24vac plastic sprinkler solenoids and they worked quite nicely at 12vdc. They could work but only on a system that used the tiny tsunami separate fill and drain pumps, so each fill/drain leg is only one way water flow. I look at that type of system once but it is too hard in the yamaha since the fill pumps have to be below the hull water line, and then you end up with 2 pumps per bag. Cam
Cam,
I have been thinking about this a little and I like what you say about 1"NPT. But for my application I believe I will try to find normally open, power to close ball valve. I want to fail safe open so we don't accidently turn on a pump with valves closed. Do you have any suggestions?
You could add a 2nd pump. Would fill and drain twice as fast.
Jim, I put 4 of these in my 212ss.
http://r.ebay.com/GijbHa
They operate with end point limit switches. You can wire it to be normally open or normally closed. It is motorized open and motorized closed. You could wire 2 of these on a 3 position switch, for left open, both open, right open. I can help with the wiring diagram if you want to go this route.
Dan144k,
Let me remind you that I am kinda a "do it cheap" guy. Although your idea does have an appeal.
Trace,
Any problem finding BSP to NPT reducers? Any flow issues with the 20mm opening?
You can order the NPT ones. BSP adapters may cost more than the valves. Just have to specify when ordering. I found this one quick
http://www.ebay.com/itm/New-1-2-3-4...t=LH_DefaultDomain_0&var=&hash=item25899959b3
1" full port, NPT, 12V, spring return open or closed. There may be better deals and ordering US vs China may have a cost implication. China is cheaper for me due to cross border fees. The CR02-02 wiring diagram was what I was looking at, 2 wire control and spring return. Cam.
PS Trace, how is your bluetooth control working out? I tried to sponsor my sons engineering group to build a BT ballast system for a project class but they ended up doing something else.
Sorry didn't see they were bsp, the ones I used were npt.
That is so sweet! I am tempted to change mine just because. I tried to use a background photo on my HMI but the pixel count is too crappy to bother. I like the video. I will have to do a video to demo mine this summer. Cam.
There are tons of apps to control blue tooth switches just as simple on off buttons. I used mit app inventor to build my app which is an object based programming utility. Takes a little bit of getting used to and I reviewed a ton of example apps to learn how to build mine, but if you've had any programming experience at all it's pretty easy to figure out.
OK @trace , what if I was interested in building this but I have no programming experience what so ever? I can machine stuff all day long. When it comes to the electrical side I am kind of stumped beyond car/boat audio.
I have programming experience, it can't be that hard to figure out. I'll take a shot at it if you want.
sstegh, if you are going to do the android app with app inventor, I can give you my app inventor build files and then you could modify it to change the background picture, macs id for the bluetooth controller, ascii character controls for the relays etc....
Jerry,
depending on whether you are running pumps or valves I can draw you a wiring diagram depending on what you want to run.
The ball valves I used had to be driven closed and driven open, so I had to wire them with a relay along with the bluetooth relay so the voltage polarity would reverse to drive the valves back and forth. If you are trying to drive a reversible pump you will have to use 2 of the bluetooth relays to drive it in both directions.
Cool, I would be running one maybe 2 pumps and then I would be running 4 ball valves. The relays wouldn't be an issue but I am glad I know that now. Saves me some frustration. I think this could be done fairly cheap from what i have seen on ebay and such. Thanks @trace I appreicate all the info and I am sure I will be talking to you about it Saturday. You as well @sstegh .
