FLJetBoater
- 242 Limited S E-Series
Very. So I just re-wired the harness portion of the ignition switch. The wires were twisted so much the brown wire had disconnected from the harness. I guess from the switch being slightly loose and continuously turned over the years. I imagine it was getting looser and looser for a while and finally gave way. If anyone knows what that specific wire does, might give some ideas what was failing.I think the voltage to the solenoid travels through the hatch switch. Maybe the weak current was firing the solenoid weakly? I have not heard of that generally the solenoid either trips or not, but this is very interesting.
Its still not to the power of the port engine starter, but definitely better.
