Boat Stuff Steering Bushing 5 Pack Half Length
  • Thread starter Thread starter Bruce
  • Start date Start date
  • Quantity Qty: 933
These are PETG plastic bushings to reduce play in the steering. They are added to the deflector nozzle where the steering rod connects.
Previously I had offered a longer version that used one bushing per steering nozzle. These are half length allowing for one to be used from the top and one from the bottom providing a flange on both ends.
Four are needed for installation. The fifth is a spare.
This is where the bushings discussion started - Adding bushings to steering deflector nozzle to increase precision (remove slop)
I recommend adding marine grease or silicone grease on all surfaces when you install these. I use a small syringe minus the needle to apply the grease.
To order click the "Buy now" button in the top right corner or click on this sentence which will take you to PayPal.
Thanks guys. Especially for the nice review from @King.
@Roy J. Infalvi Sr., I have a few hundred sets on hand. Will get your order out to you.
Just sent you an order. Let me know if your need anything else.
Sent payment for a set. Looking forward to it making a difference. Thanks!
These things worked great and made my steering good as new. Highly recommend!
Just ordered a set, looking forward to trying them out in the spring
Recieved mine quickly, they are sturdy and fit perfectly. Only 5 months to go to find out if they make a difference..... Thanks Bruce!
P
will these fit a 2023 222SD? Here is a picture of mine.
P
Yes.
There are full length and half length versions. The full length version covers the entire length of the bolt with a flange on top. The half length allows having a flange top and bottom. I have used both and do not notice a difference.
Hey I just sent payment for a set. Please let me know if you received it They are for a 2007 sx230. Thank you
Received. They will go out in tomorrow's mail.
Ordered. Blue works for me Bruce. Thank you
Hi Bruce. I just ordered a set off the old thread. The newer 1/2 Length would be great. Many thanks! -Chris
I swapped your full length for half.
@Bruce, I just ordered some as well, blue if ya got’em. Half length.
Hopefully Bruce is still around and these are still available. I just placed an order.
I am, they are and your order is shipped.
Hi Bruce. Hoping to get info on when I might expect my order. Thanks!
