Boat Stuff Steering Bushing 5 Pack Half Length
  • Thread starter Thread starter Bruce
  • Start date Start date
  • Quantity Qty: 933
These are PETG plastic bushings to reduce play in the steering. They are added to the deflector nozzle where the steering rod connects.
Previously I had offered a longer version that used one bushing per steering nozzle. These are half length allowing for one to be used from the top and one from the bottom providing a flange on both ends.
Four are needed for installation. The fifth is a spare.
This is where the bushings discussion started - Adding bushings to steering deflector nozzle to increase precision (remove slop)
I recommend adding marine grease or silicone grease on all surfaces when you install these. I use a small syringe minus the needle to apply the grease.
To order click the "Buy now" button in the top right corner or click on this sentence which will take you to PayPal.
I may have ordered both half and full length. I was hoping for the half length.
They went out this morning. USPS typically takes less than a week to deliver. You should have received a shipping notification from PirateShip .com
Just placed an order Bruce, thank you
