Seadeals
- Greenville, South Carolina
- SX
Yes, I got the 6 circuit unit that is 100 amp (5025). I debated the 30 amp circuit rating a bit (which is only online, not the packaging) as the amp has two power wires fused at 40 amps each. I thought about splitting them and taking up four fused terminal locations but have to think about the science of that “cheat” more. To be conservative, I breakered the whole supply at only 70 amps, not 100. Even though I don’t plan to push the system that hard (probably only for a few seconds to see what it will do), it is not a good idea to design a risk into a system and you need to know the weak link. I want a conservative upgrade focused on quality of audio, not sheer amplitude so may just pop 30A fuses in if I deem it an overheat risk. They blow if I go too loud.
