ldefoggi
So I know this has been discussed a lot and I did search a lot for this topic…. But I can’t seem to find the question or info I’m looking for.
I have a 2017 AR195, about 310 hours on it. I just put a new impeller and wear ring on it and the boat has been running fantastic! Had a full family load pulling tubes and wake boards with no issues.
I got on the tube with my daughter and my friend was pulling us around, after a couple runs, he went to take off and the boat would not rev past 5500 RPM. We stopped and checked everything. Nothing in the shaft/impeller, and it didn’t feel damaged. The cleanout plug was all the way seated. I checked the air cleaner box, no foam or debris in the intake tube. Oil level is good, and the are no unusual vibrations. Doesn’t seem like it’s misfiring so I don’t think it’s a spark plug or coil.
I did check to see if the SC will spin freely and this is where I’m second guessing myself. I can move it both directions, with one direction being easier than the other. Everything I’ve found in searches indicates that when these SC clutches fail the SC will FREELY spin in both directions. I’m just not getting that, so my question is if I can turn this SC in both directions, but not free spin, does that still indicate a bad clutch?
I do recall hearing almost like a whistle when the engine would idle before but now I do not. Related? Maybe I’m imagining it…
Apologies if this has already been asked, and for creating ANOTHER SC clutch thread…
Thanks in advance!
Thanks in advance!
