kpaul17
- SX
Hey everyone,
I had a minor incident with my SX195 yesterday. I was cruising in a new lake and went into a cove, got depth warning so immediately went down to 1-2 mph and hit a low spot. I actually ended up getting stuck, had to get out and pull, and reverse out - the jet pump looks fine after inspection, but the hull took some scratches and gouges on the blue gelcoat (lower hull area). I’ve attached several photos from different angles, including close-ups.
A couple of specific questions for the group:
- How bad does this look to experienced eyes? Any structural concerns, or is it mostly cosmetic gelcoat damage?
- Can anyone help identify the exact gelcoat color name/code on this SX195? (It’s a blue, but not the common “Yacht Blue” I initially thought.)
- For repair - any recommendations on products or methods that have worked well on similar Yamaha jet boat hulls? I’m leaning toward DIY with patch paste if possible or would you go with paying someone?
