PJ73
- Germantown, Wi
- X
I believe @ttzz addressed that questionThis thing is a non starter for me. If I recall the wakebooster only works on boats 2016 and newer. While it is slick, Yamaha forgot about the vast majority oh jet boat owners by limiting its use to only select years. And has anyone heard a cost yet? I also don’t need the board and rope, why would they make you buy it if you’re not going to need it?/
That's rich.So do your homework before you try to make any inaccurate comments Or implications.
This post is why I stick with @JetBoatPilot products and it's owner and staff... @Cobra Jet Steering LLC it is fine to tell us why you like or don't like a product, but in my humble opinion when you dig at other products (especially when you do it like this) you loose credibility.they said it is going to be available in January.
With a little plywood, fiberglass and epoxy supplies, a few hardware odds and ends one could probably make there own version for under a hundred bucks.This thing is a non starter for me. If I recall the wakebooster only works on boats 2016 and newer. While it is slick, Yamaha forgot about the vast majority oh jet boat owners by limiting its use to only select years. And has anyone heard a cost yet? I also don’t need the board and rope, why would they make you buy it if you’re not going to need it?/
Always a novel-length justification post with this guy.Well in my world knowing how many times people have contacted me to tell me that my competitor has maligned my systems and made statements that say my steering will rip your pump off year after year and if you know what I know about this and just look at the nonsense about the lateral thrusters supposedly not being compatible with my system and the excuse of an excuse that was given etc .
When someone throws those stones I believe you should defend yourself.
I honestly believe the wake steering caper is going to self destruct at best.
I believe that just like the past issues of water spray problems, the reverse rubbing, the controls vibrating, all past issues someone is going to be disappointed .
Now let me say that I too am looking forward to the day those hit the water. So I have good reason to defend my products .
Time will tell, after all I was correct about the bottom bolt falling out of the lateral thrusters if it was not installed correctly,
I was correct about the original cross bar no the original thrust vectors not being strong enough.
I was correct about the thrust vectors causing the reverse hood to vibrate the controls.
I was just as excited about the attempt to make steering for P W C's and the true locks did not disappoint me either.
Perhaps if people would stop and look at the entire picture things would be different I think You should get the drift. I have been around a while and I believe in defending myself and my products I actually call the rip your pump off crap the BIG LIE just like THE JET BOAT FEEL and the CUT YOUR FEET OFF guess where those sales pitches came from.
So you can be sure that if these things fail as I suspect they will I will make sure people know. If he earns it I don't want to cheat him out of it.
I have been on this planet for 66 years I stand my ground and get the job done. So happy new year! And by all means pick your poison carefully.
Send me one I'll test itMade this in like 5 mins.. Symmetrical so it can work either side...
With grab handle....
It's this by chance same dimensions as Yamaha?Made this in like 5 mins.. Symmetrical so it can work either side...
No it's just loosely dimensioned without going in the garage to take measurements. Just something I threw together to show how to make one like the Yamaha version.It's this by chance same dimensions as Yamaha?
I was wondering if the height of the plate that scoops the water needs to be at a precise depth in the water to achieve the best wake.
Here is what the guys at slingshot said about the Yamaha custom board they helped create for what’s it’s worth:I can’t wait to see what a combo of the Jet Boat Pilot Wake Thrusters and the Yamaha Wake Booster can do. I’m also pretty excited about the board. I just like the way it looks.
https://www.slingshotsports.com/2019-CoasterHere is what the guys at slingshot said about the Yamaha custom board they helped create for what’s it’s worth:
“coasts like a dream, anywhere, any time and behind any boat. Hence the name The Coaster … it just keeps going. You can get farther back behind the boat than any other model we’ve ever ridden.”
