sleek98
- Moomba
- Other
90% of the time it will be just my 140# wife or me at 195# 60# son and 35# daughter.Good deal. I have a 2021 Mojo as well and waiting on 500#s of lead to be delivered. We usually have a light crew and need the extra weight to get the amp up.
This is where I am getting confused. I thought I would need to put the lead where autowake has the 100% bag, thus making the other bags fill up to keep the same pitch and roll. I assumed the front doesn’t need weight or the system would just fill up the bags.If you have a light crew or not enough lead to compensate then you won’t hit 100% amplitude or pitch for AutoWake. When Autowake can’t achieve the set pitch and roll it will try and compensate by dumping ballast to achieve those number. You end up with less ballast in the boat which means less displacement. AutoWake it mainly a tool to use and try to consistently achieve the same wave every time. The trick though is that it #1 needs weight on the boat first for the system to be used properly. Wether that weight comes from people onboard (medium to large crew) or comes from lead is the same as what the system sees.
For your boat the recipe is probably the same as most others. I would probably start with some bias towards the bow than the stern. That will help you hit the 8.5-9 degree pitch. For instance I bought 500 lbs of lead by 300 of it is in the bow and 200 is in the stern under the rear bags. I’ll fine tune placement of the lead once we get on the water but from everything I’ve read they like to have a little bow weight bias as you already have more rear bias in the factory system. The running attitude of the boat will already add a little pitch so it makes sense adding lead to being the front down.
At the end of the day what you want is running near full ballast all around and use your lead (or people) to fine tune the pitch. The roll usually takes care of itself once the surf tab is deployed so I’d focus on pitch as you’re likely already hitting your roll numbers.
When we were testing the system Saturday afternoon showing her cousin we had an additional 250# of people in the back and another 175 in the front. Autowake said to move weight to the stern, and the front back was only 25% full. Wonder if it’s possible I need to have the sensors calibrated.
Then again the wave got worse the longer I rode it. First time I got up the wave was good. It was pretty dang small by the time I got done with my third long ride. It started raining on us around noon so I’ll have to keep messing with it.
I need to figure out if it’s possible see the pitch and roll gauges without autowake on so I can see what it’s doing before dumping water
