haknslash
- Lake Martin, AL
- Moomba
- Other
@haknslash what can I expect when backing up the Moomba? I have a slip where I will need to back the boat out and turn the stern to the port side to get out to the lake. I have heard that because of the rotation of the prop that the boat will pull to the starboard side when backing up. The area where I will need to back up is somewhat tight with another finger of boats behind me.
I'm sure with some practice it can be done. You'll just need to learn to over rotate the right amount to counter act the prop kick. It's not so much an issue going forward, but can be a pain in reverse. There is a stern thruster on the market that's designed to be an add on, but they are about $5k. If it is that tight of a spot, it might be totally worth it.@haknslash what can I expect when backing up the Moomba? I have a slip where I will need to back the boat out and turn the stern to the port side to get out to the lake. I have heard that because of the rotation of the prop that the boat will pull to the starboard side when backing up. The area where I will need to back up is somewhat tight with another finger of boats behind me.
www.jetthruster.com
Everything i've read about vdrive boats is that they're worse than a jet to dock. BUT, they do make stern thrusters for most models now too, which is supposed to make docking like butter.
The key to going backward to port is just to use very small moments of reverse to get moving, then rudder in neutral while moving astern, then momentary engagement of forward & countersteering to rotate the boat, then back to momentary reverse until you are pointed the way you want to go. It sounds more complicated than it is. These boats don't "clunk" in and out of gear like an I/O and you will probably never need more thrust around docks than idle speed will provide.
