Chadharter
- FSH Sport
I know this has been talked about a million times. I thought I had a good plan but I struck out. My idea was to use the large drain at the back and run the transducer cable through there, put a Tee in as other's have done with the other drain, fill it in and I'd be good to go. Not so fast. The hose used for the large drain (which has a tee already in it under the bucket storage) is not a standard size. It won't fit a 1 1/4 tee. I don't have any interest in splicing the transducer cable and I really didn't want to drill any holes in the boat. I decided to mount the transducer to the bottom of the ride plate like a few others did. I'm now resigned to the fact that if I don't want to splice the cable, I'm going to have to drill through the boat. In the attached picture, what do you guys think about doing a through hull fitting in the marked location? It would be above the water line, mounted vertical, not horizontal. I'd be using this through hull fitting:
https://www.amazon.com/Amarine-made-Hose-Stainless-Steel-Barbed/dp/B01NAPG778/ref=nav_custrec_signin?tag=hyprod-20&linkCode=df0&hvadid=167155426463&hvpos=1o5&hvnetw=g&hvrand=13465868071166171618&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9016618&hvtargid=pla-313971327334&psc=1&
