FSH220Now!
- FSH Sport
Hi all, I'm preparing to install a new Minn Kota Riptide Terrova Trolling Motor
112 LBS (36V) / 72" on my FSH 220
I'd like feedback on the parts to ensure I'm thinking correctly. I'm new to this and have been doing a lot of research, but I still have much to learn. Any help is much appreciated. So far what I have is:
I am planning on installing the batteries on a tray just forward of the center console storage area. I'll probably have to build something for this specifically. Any help on this is greatly appreciated. I plan on getting the parts together and wiring it in my garage prior to install on the boat.Thanks!
6 Gauge Marine Wire Tinned Copper Boat Cable, Standard USA OFC Oxygen Free Copper Wire | |
| Minn Kota 1865106 MKR-19 Waterproof Circuit Breaker Marine Motor Accessory, 60 Amps, Large, Black by Minn Kota (Sports) | |
Minn Kota 1865108 AC Power Port-Black / MKR-21 by Minn Kota (Sports) | | |
Minn Kota 1854017 Quick Release Bracket / RTA-17 White by Minn Kota (Sports) | | |
Cable Lug Crimping Tool with 170pcs Copper Wire Lugs and 210pcs Heat Shrinkable Tube, Wire Crimping Tool for AWG 10-1/0 Electrical Lug Crimper, with Cable Cutter by Mdvora (Tools & Home Improvement) | | |
1865120 MKR-28 Trolling Motor Plug and Receptacle For Minn Kota Freshwater and Saltwater Marine Boat Battery Accessory Male Female Connector Socket Waterproof Heavy Duty 8AWG Rated To 60A Up To 48V by E-cowlboy | | |
AWBLIN Upgrade Battery Disconnect Switch with Voltmeter, DC 5-60V Master Isolator Cut/Shut Off Switch for Marine Boat Car Truck Camper RV Trailer Vehicles Engine Application (On/Off) by AWBLIN | | |
LiTime 12V 100Ah LiFePO4 Battery BCI Group 31 Lithium Battery Built-in 100A BMS, Up to 15000 Deep Cycles, Perfect for RV, Marine, Home Energy Storage(3 Packs) by Litime | | |
NOCO Genius GEN5X3, 3-Bank, 15A (5A/Bank) Smart Marine Battery Charger, 12V Waterproof Onboard Boat Charger, Battery Maintainer and Desulfator for AGM, Lithium (LiFePO4) and Deep-Cycle Batteries by NOCO (Electronics) | |
