- Lake Ray Roberts, Texas
- Boatless
- NA
- Other
- NA
It would be under the sections. Except for having to be at least a couple feet outside, so you can lift the arch and set its lip on top of the previous arches lip, and install all the bolts two feet over the top of that arch on the previous arch. Leaning while standing 15' over concrete isn't appealing, so I want to make sure that I have adequate surface and stability to do this job without incident or accident. The manufacturer uses and recommends the use of scaffolding and extra hands vs lifts. Because more hands are needed to position and set, as well as put them together I guess. But they say they too have used both. The lift can be a real asset, but I'm guessing I will still need some scaffolding. Under a 20' wide building, room may be a bigger issue. Ideas?
