Zinc anodes
Rhino
Humble, Texas
I have seen many post about changing the mag anode to zinc but can find where to order all 3 from.. Help?
zipper
Boston Whaler
druppert
Tampa, FL
Great question. Following for a solution as well
haknslash
Lake Martin, AL
Moomba
What type of water are you boating in? Do you store your boat near shore power or where electrical current could be? If boating in freshwater magnesium is what you'll want. If you use zinc in fresh water it's just going to oxidize on the outside preventing the zinc from doing it's job. If you're in brackish go with zinc.
druppert
Tampa, FL
I split my time about 70/30 salt/fresh water. The mag anode appears to work as it’s pretty pitted & there’s no corrosion whatsoever anywhere else after 100 hrs but I was going to leave the magnesium anode on one side of the pump and add a zinc on the other side. Any thoughts on this? Would the different types of anodes interfere with each other?
druppert
Tampa, FL
@haknslash would you mind elaborating on the question about electricity? I don’t understand much about the chemistry at play.
Rhino
Humble, Texas
Brackish mostly
haknslash
Lake Martin, AL
Moomba
This is a nice article for ya http://www.boatsafe.com/nauticalknowhow/012000tip3.htm. Just pretend where they mention props and other components of a "non-jet" boat they are talking about your pump housing instead ;)
Edit - this is also a good read on different types of anodes https://www.boatingmag.com/how-to/choosing-right-sacrificial-anode
zipper
Boston Whaler
Cobra Jet Steering LLC
you can adapt just about any zinc and there are empty mounting castings on the right side of your pump so adding one is easy just remember to leave room for the steering nozzle to turn fully.
druppert
Tampa, FL
In case anyone needs measurements mine (2017 19’) is 4 1/2 x 2 x 9/16 with a 3 1/8” bolt pattern. Old threads on this topic recommend boatzincs.com. I found a couple of options:
1 of these:
http://www.boatzincs.com/hj-104634-specs.html
OR
2 of these:
http://www.boatzincs.com/h2b2.html
The mounting point has a sufficient base where the button type could be mounted independently from one another and give roughly the same surface area as the stock rectangle anode. The 1st one is a bit narrower and shorter than stock but it’s also slightly thicker. I think I’m going to order the 1st one.
Remember you can always make an aluminum plate and mount it to the bosses on the pump with the anode mounted to the plate so obviously you drill the appropriate mounting holes for that anode to go on the plate etc. allowing you flexibility to mount any anode any place convenient. I have several
druppert
Tampa, FL
From the links everyone has shared the magnesium is the most aggressive, zinc is the least aggressive, & the aluminum is in between. The boating magazine cautions against wet slipping a boat equipped with magnesium but doesn’t describe what “a catastrophe” entails. I guess they were preoccupied with their next food pun. What is the risk of using an overly aggressive type of anode other than a short lifespan? I can live with that as the magnesium anodes are a hell of a lot easier to get.
