Babin Farms
- Lower Alabama
Your joist spacing is way too large for that trex, gonna be wavy as hell after some hot summers. You can barely get away with 24"oc with the non-scalloped boardsJust finished up with what I believe is the last of the nailers and waiting on joist tape to arrive. Probably pick up deck boards tomorrow or Tuesday evening and at least get them on site.
What’s the suggestion?Your joist spacing is way too large for that trex, gonna be wavy as hell after some hot summers. You can barely get away with 24"oc with the non-scalloped boards
Try and get to the other side of that hole so you can seal up the fiberglass.So it rained a few days ago and I didn’t think much of it, until I saw this under my boat.
It’s funny how perception changes with age and experience. When I first started boating over 25 years ago i would have thought this is terrible and possibly expensive and time consuming to fix. Now I think, it’s not that bad. The darkest spot is a chip not a hole and the fiberglass / gel coat in that area is still hard as a rock.
View attachment 218257View attachment 218258View attachment 218259
I plan to. It burns because I caused the problem when I installed mounts in the head compartment to hold the table leg, i used a couple of screws that were just a bit too long. I’ve since back the screws out or removed them but the only way I can get to the area from the inside is to drill some bigger holes in the floor of the head compartment / inner hull. Not a big deal but it has to get done correctly or I may be looking at a much bigger issue in the future.Try and get to the other side of that hole so you can seal up the fiberglass.
Time to install a floor access panel in the head......I plan to. It burns because I caused the problem when I installed mounts in the head compartment to hold the table leg, i used a couple of screws that were just a bit too long. I’ve since back the screws out or removed them but the only way I can get to the area from the inside is to drill some bigger holes in the floor of the head compartment / inner hull. Not a big deal but it has to get done correctly or I may be looking at a much bigger issue in the future.
I like it and cost is not an issue but it requires a much bigger access hole be cut than I was originally planning on. I was thinking of using a 1” to 2” hole saw where the screws were.Time to install a floor access panel in the head......
Innovative Access Plate - 9" x 14" | Boat Outfitters
If that's Trex enhance like I believe it is, the manual says minimum 16"oc with 12"oc recommended, stairs should be 9"oc. Just built a deck with the stuff, have to be very careful to make sure your joists are in plane as well or you'll get waves and standing water.What’s the suggestion?
More fantastic wildlife photos!This mallard did a nice job of patiently posing for me a couple of days ago. I was out looking for nesting blue herons, but this guy stole the show.
View attachment 218331View attachment 218332
