Anchor That Fits Anchor Locker
InTooDeep
Las Vegas, NV
Does anyone have an anchor they can recommend that will fit the front anchor locker on a 2023 AR250? I bought one, but the door would not close with it hanging and I haven’t really seen a different design that might work without causing interference with the door closing due to being too tall above where it’s designed to hang.
sastocky
Here is a photo of the anchor label from my 2021 AR250.
kgower
Buford, GA
222SE
zipper
Boston Whaler
The crown on the Danforth is taller, more offset from the stock than the usual sliding ring anchor that I think they design for.
On the sliding ring...the crown does not stick up as much over the stock. Personally, I don't like sliding ring anchors.
anmut
I have a stainless steel rod that hangs my box anchor in that compartment. Cut the rod to fit and insert it through the folded box anchor.
Tranquility Base
kgower
Buford, GA
222SE
I tried the Five Oceans version (Amazon.com : Five Oceans Boat Anchor - Fluke Anchor, 9 Lb, Galvanized Steel Slip Ring Boat Anchor, Boat Anchors, Small Boat Anchor for Pontoon, Dinghies, Fishing Boats, Small Boats - FO4557 : Sports & Outdoors) but the stock was too short. The 1st one I bought the crown was too tall. I ended up with a Fortress FX-7 and cut about 3/4' off the stock.
