Bilge light on but won’t run
Thorn1je
AR192
Hello- needing help! I have a 2015 Yamaha 192ar that got left outside in a huge rain without the cover and until then the bilge was working fine and now this morning when I need to get water out of it, it won’t work. The light comes on. Any help would be appreciated. Thanks!!
2kwik4u
Georgetown, IN
That age....it's likely clogged or dead. They're inexpensive at the dealer, or through other vendors. Relatively easy to replace as well.
Lots of info form my bilge pump journey in this thread. I have a '17 AR190. I think it's the same as yours.
jeffrt
Belle River, Ontario
You should be able to unsnap the pump from the base to see if something has jammed it. If it's all clear, then I'd verify you haven't popped a fuse.
2kwik4u
Georgetown, IN
How do I see if I popped a fuse? I cleaned filter and put it back in the base and nothing.
Circuit breaker is right under the switch on the dash. Push it in. If it clicks, then it was "tripped" if it does nothing, then it was not "tripped".
Likely a dead pump if it doesn't spin for a few seconds as soon as you flip the switch on.
Scottintexas
Corinth, TX (DFW)
do you have a multimeter you can check for electricity at the plug ?
you could disconnect the pump and check it direct to the battery with two spare pieces of wire
FSH 210 Sport
Tranquility Base
I dont think the light will come on if the breaker is tripped?
FSH 210 Sport
Tranquility Base
