Changing Yamaha Jet Boat Pump (Duct Housing) Bearings and Switching to Oil Bath Lubrication
FSH 210 Sport
Tranquility Base
Bruce
Royal, AR
Just pulled my pumps to top off the oil in rear bearing housings. I believe that July of 2018 was the last time I had opened up the cones. The bearings look good and feel good. They were installed in 2016 so six years on the bearings and four years since I have topped up the oil.
Both cones had a nice vacuum seal when opening. Both had significantly less oil than I initially put in but the bearings were well coated. There was no sign of water intrusion.
How the gear oil escapes remains a mystery.
I poured out the oil and found it to be a thick slurry with the grease I had packed the bearings in.
This is starboard
This is port
I filled the housings with fresh gear oil then I filled the cone with marine grease. I believe it will mix once the shaft starts spinning.
Cobra Jet Steering LLC
Vendor
Florida
I make sure I use some silicon seal on the o ring when I put the cone back on just to be sure it seals good
