downrigger mount on tower rod holder
Ray88
HI, I have ar190 and thinking about mount a downrigger for salmon trolling. one solution is install a flush mount rod holder and put downrigger in on a gimbal mount. Another solution not sure if it works is have a solid clamp mount rod holder on the tower and put the downrigger there through gimbal mount. the second solution kinda appealing as it doesn't require drill big hold. I wonder any suggest there and any body did similar thing and what is the experience so far.
thank you
FSH 210 Sport
Tranquility Base
thank you
My suggestion would be to add a 30° rod holder on each cap rail so you could put a down rigger on either side, or run two down riggers. While I did not look reeeeely hard I could not find a zero degree “gimbal” mount, only those made for the 30° rod holders. I get not wanting to drill a big hole in the cap rail, but it seems like using a clamp on rod holder on the tower would be difficult to use. Maybe you could drill an even bigger hole and put in a combo drink holder / rod holder so it would be functional all the time?
zipper
Boston Whaler
I agree with @FSH 210 Sport on adding rod holders in the gunnel. They can hold a downrigger, a rod with dipsy divers and even a grill to catch and cook on the water. We use a rod holder to mount a grill on our sailboat. I mounted downriggers on swivel bases on the gunnel of our Whaler.
