Do you use the same grease gun for the pivot points or maybe a marine spray lubricant would be easier for those? Since there is no required measurements of grease on those points.
Ok... so it looks like this is where my bearing housing is. Pretty crappy all the way in the back and underneath a cover. Would I need any sort of 90 degree adapter for the grease gun tube connector? It seems like a pretty tight fit when I put my hand underneath.
In order to grease the bearing housing, I laid down on my stomach, on top of the motor, and had an 18” flexible hose on my dedicated Marine lube grease gun.
I was not exactly a graceful picture, but I got the job done.
If you don't mind, which dealer did you find that was willing to come to house and do service in NJ? We are NW NJ and nearest dealer is Highway Marine. They quoted me around 625.00 for this service. (10 hour) I have a lot of automotive experience so I think I'm just gonna study up and do it myself. But it would be nice to have option of home service. Thx.
Seems very exact..... 1.1 oz bearing grease.
But then it gets vague......says you can do it yourself at 6 months or 100 hours ( big difference) and it does not tell you how much grease to use at that point.
This is an old thread, but I'll be coming up on my 10 hour service here very shortly. Seems a point of concern is warranty coverage. YES it is true yamaha could deny a claim if you haven't had it serviced at a dealer. HOWEVER, just received all my paperwork from my Y.E.S warranty and here's what it states in regards to who does what as far as maintenance goes and what you should do about it.
You can do 1 of 2 things a.) use the maintenance log provided with the Y.E.S contract and filled out by the dealer b.) keep receipts and other records that show dates, "mileage", elapsed hours of use, costs, services, and repairs performed.
So there ya go, exact verbiage from their documentation that as long as you document your own service, then them denying your claim is likely not going to happen. Which reminds me I need to go ahead and order the kits as I'm sure it'll take a bit of time to get here with the Rona going on.
DAD GUM! But hey as long as you're comfortable paying that, then by all means who am I to judge. We're hitting peak season and I'd rather not be without my boat for an extended period of time. Nor would I like it stored outside while it awaited service, or awaiting me to pick it up.
How many people actually pull their spark plugs and check them at 10 hours? That seems excessive for a modern 4 stroke engine.
One of the main reasons I went with a Jet Boat is the simplicity of the propulsion system and ease of maintenance. Truly if you have room at your house, doing the 10hr and annual maintenance on the boat is much easier than dragging it to and dealing with the dealer. If I had to use the dealer for maintenace on my boat, I probably would have stuck with a stern drive.
I am scheduled for my yearly service (same as 10 hrs - oil/filter/grease/inspection/lubrication of cables and etc.) next Tuesday. My dealer price in Savannah is $266.23 - includes all fees and taxes. Dealer sends the work order with all pricing, prior to service. It is approximately the same price as last year.
