10 MPH maximum speed for 7000 rpm and vibrate
ddonoso
CT
My 2017 AR goes at 10 MPH maximum speed for 7000 rpm and vibrates. It goes away after we stop for a while.
Cobra Jet Steering LLC
Vendor
Florida
something is in the pump or around the driveshaft
Babin Farms
Lower Alabama
Cavitation. You’ve got something in your pump.
zipper
Boston Whaler
X3 on sucking up something. Pull the cleanout plug and inspect the driveshaft, intake grate and tunnel.
drewkaree
West Allis & Fremont, WI
...and stop running it up to 7000 rpm. Until it's cleared/addressed, you aren't going to go any faster by giving it more gas, and you may be creating bigger problems for yourself
johhnyboat
Ocean City, MD
This happens to me every once in awhile. Use the reverse trick (search in forums) and it clears it every time.
ddonoso
CT
Where the pump?
Babin Farms
Lower Alabama
You propulsion pump that makes the boat go
ddonoso
CT
I'm new to boating, how do I do that?
drewkaree
You need to find, download & read the owner's manual for your boat. You cannot just blindly go out without knowing more about your boat, and having at least some working knowledge of the proper operation of your boat, and something to look to, in order to troubleshoot problems that very well could have you stranded and/or potentially in peril.
I'm not trying to be the "RTFM" guy, but your responses read like you haven't investigated how your boat works prior to taking it out on the water.
zipper
Boston Whaler
On the upper swim platform section there is a hatch. Unlock the two handles and open the hatch. In the center of your hatch, cleanout tray is a hole housing the cleanout plug. Release and remove the big plug. Once removed you will be able to look down into the jet tunnel forward of the impellor. Inspect the area for any debris and remove any weeds, line, rope, wood chips, toothpicks etc. from the driveshaft and impellor. Once done reseat and lock the cleanout plug. Close and lock the hatch and you should be ready to go.
biffdotorg
Pelican Rapids, MN
Or get it on a trailer and look inside the big hole in the back that normally looks like an open fire hydrant when the engine is running.
Shine a flashlight in the grate under the boat as well. Looks like a pasta strainer. Pretty sure you have something in there, and if it went away, it blew out.
