jacoviii
- Independence Mo
- 255XD
Not sure. I will look but I have put more info on here then on FB. What are you needing?
See pic
Ok ez thing to do is the treble mid and bass adj listed above.
Option 2 is add a line driver / bass booster this will help a lot
https://www.sonicelectronix.com/cat_i494_bass-restoration-expanders.html
Option 3 Cut the sub RCAs input wires going to the HTX6 amp they are not used anyways. Put RCAs on the end. Pick a amp that will run both of your subs.
If you add just a new amp and sub and still use the stock sub on the stock amp sub channel they may play at different Frequencies and could cancel each other out a bit
Yeah I downloaded the app and adjusted the settings on the Fusion HU. I keep reading posts about rewiring the port cabin 6.5 speaker to have it run parallel vs. in a series. I am planning on just re pinning the plugs on the amp to allow for each speaker to run on its own channels. Then take your idea and tap an RCA off the HTX-6 that isn’t being used for the sub and run that amp to power my WS sub and maybe another sub on ill add on the drivers cockpit area. Last thing is possibly running a new power cable from the battery of just t tap with a Stinger Distribution block for the 3rd amp and double the fuse amps. Anybody running a capacitor on their boats? A buddy recommended it vs. a distribution block for piece of mind and even out the current draw from the batteries when just floating.No it is on the HTX4 4x100 so 400w @ 4ohm 2 channels are running both of the Icon8" 100x 2ch and 2chs running the sound bar 100x 2ch The sound bar is rated at 75x2 RMS and 150x2 max so it is about right.
Have you adjusted the Zone settings on the Fusion yet. Also down load the Fusion APP to your phone it makes it EZ
The parallel vs. in a series issues you read about are the older boats running polk amps
I just bought a 2020 242x and I was trying to add a sub and amp because the wet sounds system isn’t sounding great to me. I’ve been trying to scour the forum and got on this thread but I’m not smart enough to figure out what y’all are saying lol. So I’m just trying to figure out the easiest or best way to add more bass. I’ve seen you talk about cutting wires to run the sound bar and sub on its own amp.
The flash was on early '18 boats that had the L & R wrong on the boat but correct in the tower. I doubt you have that issue. But you can fade side to side and see.
