Brad Dunn
- British Columbia
- Other
2016 242 x I beleive I have a battery going bad or not wirred correctly. It is not charging. first what switches should be on or off.
parallel switch?
emergency switch? off im assuming
house and start battery? both on?
what do you leave on when parked out of the water or in the water?
should a guy run a 3 battery system, we do like to float and listen to the stereo.
Thanks for any info.
parallel switch?
