How can I tell if is was a project boat or one that was totaled and rebuilt? Going to look at it in a couple hoursI own a 2006 SX230. Things I noticed on the pics of the boat you're looking at are: SBT sticker, as mentioned, no graphics on the boat which may indicate it was repaired, repainted or the previous owner just removed them. The reverse bucket opening doesn't appear equal between port and starboard. I also noticed the upholstery has been redone. This could have been due to sun damage, neglect or accident. I would look closely at this to make sure it is as stated. Make sure it wasn't a project boat or one that was totaled and rebuilt. I'm wondering if this was a dressed up SR 230.
One engine won't start, not looking good
One engine won't turn over. Valve on back of jet drives are very loose. No bushings. Is that correct? The scupper valve looks like flat plastic will take better pic.What are the symptoms? Does it try to crank and not start?
Was it a Yamaha mechanic? I don't recall hearing about anyone on this forum with a bad starter solenoid...ever. Not saying it couldn't happen, but with these boats, the most common thing is one of the safety switches (cleanout hatch, throttle binnacle, and safety lanard, or the key switch)We took it to a mechanic and he said it was the solenoid why one engine wouldn't start,
are you sure the ENGINES are definitely different? All we can tell from the picture is the air cleaner covers have different decals. Maybe just has a cover replaced.definitely two different engines in the boat,
Paint??? Where? If the gelcoat has been polished and waxed, that is completely normal and considered regular maintenancealso it looks like there has been a fresh paint job.
well having one engine not start is a show stopper, but it may be an easy fix - even it is the solenoid.He said he would get it fixed and call me next week. Not a good gut feeling though
he sbt sticker and what appears to be two diff engines would always sit in the back if my head and bother me.
Agreed! Is there a car fax for boats?The weird thing is that SBT replacement engines are fairly stripped. The intake covers are different but would not have been part of a SBT replacement. This boat must have some interesting history.
These guys are right and very honest, that said much better maintained and newer Yamahas can be purchased for a 3-4 thousand dollars more. This one seems like is is just a hole in the water you will be pouring money into. Spend a little more now and you could enjoy your boat and have many hours of trouble free boating. Just my $ .02 after purchasing an 07 AR last may.I avtee with @maboat ... there are much nicer boats out there... mayne not for 15k but i think i would walk from that one..
