KXCam22
- Kamloops BC
You cant get accurate fill sensing on a bladder in a constrained compartment without complicated hardware. I use a full signal, and empty signal and a timed bar graph that shows fill level. They always fill at the same rate so the graphs are pretty accurate. But you need a plc or higher end hardware to do it. I researched many other ways. The relay controller or plc can end up saving a bunch of money on other parts if you plan to build something with a few more features. For ex my plc was $80 and two pump timers were $100 each. The 1" hose i used is gates greenstripe heater hose. This was for intake to pump, and underfloor pump to ski locker bag. Very nice. Even the nicest ballast hose is mediocre and does not seal the best. As a suggestion, add some drain/blowout fittings for winterizing. I had to add mine later. Cam
