2022 AR 195 White Smoke/Exhaust
Dud8198
Hi — my 2022 AR195 lets off white steam or smoke from under the back of the boat sometimes. It usually happens when I speed up from low RPM’s to higher RPM’s. There are no engine lights. Boat has 45 hours on it with the last service at 10 hours. Is this normal? It’s my first ever boat. Thanks.
Dave burke
Near Lake Placid
dont recall ever seeing this on my boat. What were the weather conditions when it occurs? Does it happen every time you accelerate?
Thermobrett
Lithia, Florida
SX195
Every once a while I will see some white smoke come from the back of my boat when accelerating. I think its just the added pressure in the exhaust during acceleration and the boat coming on plane that makes you see it. Most likely it goes away once on plane?
FSH 210 Sport
Tranquility Base
If it’s cold out you are going to see steam which is from the hot cooling water….
Thermobrett
Lithia, Florida
SX195
When flushing my boat in the driveway after I use it I don’t see anything. But that also at lowest idle too.
Farny
Spring TX
Centurion
Lik
Likely steam if intermittent
steve0617
Littleton CO
AR195
My 19 195 does that too when on the water. Doesn't bother me.
Thermobrett
Lithia, Florida
SX195
Glad this thread popped back up. I brought my boat home today, changed the oil and plugs and flushed the engine just to get the oil flowing and charge the battery. Same with mine, I believe it’s just steam as @FSH 210 Sport indicated. The engines run hot and as soon as water flows through it you produce steam. No indication of burning oil when I smelled it.
212s
1000 Islands
212S
I concur...once warmed up, the engine thermostat will open and pass hot water out under the swim platform. If you look under the platform, you will see about a 1" port above and to the side of the jetpump - that's where the hot water is returned. After coming off plane, and idling into docks or coves, you will notice some steam from the hot water, especially when the water is cool. We notice it the most in the spring when the lake water is cold.
