Carolina Rob
- FSH Sport
This is my first post so I will apologize up front if I have broken the etiquette with the length of my initial post. I wonder if the system will allow a post of this length?
My wife and I looked at the 210FSH SP and the 190FSH SP, in fact I put down a deposit on the 190FSH, but at this moment I am leaning towards the 210. We have an appointment to return in a few days to test drive each. I would appreciate any thoughts you may have on the following:
1) The 2022 model of the 210 has 3 batteries and 3 battery switches, which supposedly allow for longer trolling times and you can actually use all 3 to start if necessary, also if I understand the sales rep, you can direct all of the charging to a specific battery. Your thoughts?
2) Have any of the know issues with the previous models been corrected in the 2022 models, for instance tracking in a straight line, lack of steering control at low speeds and in reverse, noise issue from engine (does anyone bring ear plugs) does adding more sound insulation help, (decibel levels around 99) at WOT?
3) The 190 had black powder coat on the T top rails. I am concerned that they may get too hot making them difficult to hold onto on hot days and will be hard to keep clean since it was a rough finish which will be great for gripping though? Your thoughts?
4) I do not recall seeing a factory installed mounting bracket or hole (when we looked in person) for a front pedestal seat on either the 190 or 210, despite seeing this option on previous year models. Does anyone actually use he seat? Has the seat been removed?
5) I was a little shocked when the dealer told me the approximate cost of the 20 hour scheduled maintenance costs, as well as the 100 hour. What has been your experience with either the 190 or the 210? The quotes were $800-$1200 and of course with the 210 being on the higher end because of the dual motors.
6) I am wary of the fact that Yamaha only gives a 1 year warranty on the motors. With the quality associated with Yamaha in general, I would at least expect 3 years, like their equivalent outboards. Has anyone done the leg work on comparing these 2 engines installed on their jet skis? Do they also only have a 1 year warranty on the jet ski engines, if not why? Also what about the long term reliability of these same engines installed in a jet ski?
7) How often do items get stuck in the impeller? Is it obvious from the sound and lack of performance when this happens?
8) I was impressed with the perceived quality of the included aluminum trailer. Almost seems to good to be true. Your thoughts? Any issues with the trailer?
9) Was it difficult to learn to dock and get it into a boat slip? How long did it take for you to master this skill?
Thanks
Rob
Thanks
Rob
