Welcome to Jetboaters.net!
ISLAND JAY has your Jetboaters.net Clothing, hats, stickers and more all at a 30% discount until June.
Click Here for more information>SWAG for JetBoaters.net members only
On my '14 AR240 I blow up with air, take a ratchet strap and go from the rear tow point, thru the top handles on the bag, thru the rear cleat, back thru the bottom handles and to the chrome handle directly above the ladder.
It doesnt move AT ALL and we are agressive with out our turns to downed surfers.
I do put a rag between the metal part of ratchet strap and where it touches the bag for added protection.
So true if it is completely filled I have never seen it move or any of the ropes even getting tight like it was moving. If the water can't move inside the bag it shouldn't move. Now we have only filled it 75% just to try and I can see the water moving back fourth with movement. The wave wasn't good so we never did that again.
@jcyamaharider Let me know when bags come in please. I’m going to order a bag and a pump. Do you have any adapters that allow the tsunami pump to work with the ronix bags?
You should spec off the outlet you install, not the pump. I installed the blue sea socket and swapped the pump plug for the blue sea version, so it locks in place. I would recommend that for sure. The blue sea 12v socket is rated for 15 amps, so I used a 15 amp fuse. https://www.bluesea.com/products/1015/12_Volt_Plug_with_Dash_Socket
How long do you guys take to fill the ballast? How long for the custom swimdeck bag?
I was just rereading the thread and figured maybe I'm complaining too much about the drain size being 3/4" rather than a full 1" in the custom, albeit it is the slowest.
So, with my whole system (rear port and strbd, and center locker - all 800lbs nominal, and the custom for the deck) I'm done in under 10min total, but the swimdeck bag takes the longest, just about 8-10min depending on the voltage I run - when "idling".
My port and strd and center locker take 4-5 and ~6minto fill, respectively. The port and strbd are filling only 500-600lbs, center is about full 800.
Same time to empty, except the swimdeck bag where I open the drain as well so it goes double speed.
I have a Eight.3 Ronix Telescope Ballast Pump 3700GPH and it quick/disconnects to the ronix bag that I have for my platform... it fills up so fast I end up scrambling to try and shut it off... it's unreal, like 2 minutes and there's 80G in the damn thing.
Not sure if that's the information you're looking for
I bet you have a 1” intake/drain though.
The custom bag is 3/4” quick connect, that’s what I was debating. I think that 3/4” really slows it down a bunch but I can live with it, I realized it’s not that slow really, it’s just slower than my other bags.
