dalcini
- Utica, Michigan
- 242X E-Series
I would appreciate any comments advice on my LTS (long-term storage) checklist below.
I also have questions that I couldn't find definitive answers for:
QUESTIONS:
Edit: added #19 & 20
QUESTIONS:
- I've seen some discussion questioning whether removing the air box is necessary to fog the 1.8HO engine. Do some people just disconnect the breather hose and fog through that port? (thanks to @Leojay for the excellent videos by the way)
- It looks like most recommend changing the oil before storage - would it not be better to give the motors fresh oil in spring before running? Or is the idea to get the impurities out of the engine before it sits in the off-season? (...hmmm, may have just answered my own question.)
- What (if anything) do I need to do to prepare my ballast bags and ballast system for freezing temps? Antifreeze flush?
- Has anyone ever removed the oem SIDE ballast bags from a 242X? The center bag was easy to remove, so I'll probably keep that in my garage - but I have no idea how one might get the side bags out (for maintenance/repair/cleaning, etc.)
- Add 50oz (1oz per gallon) of Fuel Med RX to tank (or Marine Stabil stabilizer)
- Fill tank to mix it in. (this introduces stabil into the engines during fogging in later step. Many use stabilizer all year)
- Fill fuel tank
- Find/Download Yamaha tech exchange bulletin on engine fogging. (see Captain Leon's video.)
- Fog for 5 sec through air intakes while running:
- Prepare by connecting water to flush port but don't turn it on
- Start Engine then immediately start water
- Spray fogging oil into intake for 3-5 seconds
- Stop Water, half throttle blip 3 secs then stop.
- Pull plugs & fog for 5 secs in each hole
- Pull kill cord, towel on head & crank for 1/2 seconds
- Put anti-seize on spark plugs
- Replace plugs & torque to 18.4 ft-lb.
- Open fuel tank hatch - check for issues and clean it up.
- Drain or antifreeze ballast system???
- (OM Pg.172) Grease steering & reverse cables
- Lube cleanout covers with silicon seal or beeswax
- Leave cleanout covers out (somehow)
- Remove batteries (store in garage on tender)
- Remove tower speakers (store at home)
- Put trailer on blocks to remove weight from tires?
