JetBoatPenguin
- Lake James, NC
Looking for advice from the group . . .
I have 2 Duracell Marine Group 31M AGM batteries on board the Yamaha.
I bought a Minn Kota Precision MK 330PC (3 x 10 amp) onboard charger to charge them.
I had 2 of the 3 lines attached to the house battery.
The boat is on a shared pier with about 9 slips on it....
When I plug in my charger - it blows the pier circuit breaker.
Others on the pier have boat lifts and chargers plugged in.
I guess my charger pulls too many amps when combined with the other loads being pulled at the dock by my neighbors.
I wanted a 10amp per bank charge given the batteries are AGM.
Any 2 bank alternative charger with a lower amp pull the forum would recommend? Or ideas on how to troubleshoot avoid blowing the dock circuit breaker?
Genius
ProSport
When all the other boats are unplugged . . . my charger still blows the dock circuit breaker.
There are two breakers 20 amp each.
I was concerned about charging the AGM batteries at a rate lower than 10amps per bank . . .based on other forum threads.
Thanks....
Genius
ProSport
Thanks....
