Ron@Scarab
- Fort Myers, Florida
- Scarab
- HO Impulse
Ha! You said Marine Max. Problem solved.
I bought it from Riva. I would but it is such a long ass drive. Im going to give this one more shot in Orlando. Im feeling like at this point if I drive it to Riva I won't be bringing it home.
Ive never hated a piece of machinery ever like this. I remember my first car... It was a real POS and it didn't breakdown as much as this boat. I loved that car!
Thanks... I called Orlando and they are so busy couldn't take me till next week. Cocoa MM called and have room so when I get back from vacation I will drag it down there. Thanks for the info guys.
Update...
O2 sensor bad... 5 or 6 now... (2nd for this motor).
One bad spark plug.
ALSO... LOOK OUT!!!
This was mentioned before so I had them check. My BOAT CLEATS WERE LOOSE. The techs only could get to the front and back ones. So that's awsome.
Got the boat finished quick so thanks Cocoa MM.
At the risk of sounding like an idiot, I sure hope this thing only runs a rear 02 sensor, otherwise you're both providing some piss poor information here. My instincts tell me if it does indeed only use 1 sensor, it's a front sensor, and you're both WAY off the mark. My apologies in advance if my assumptions are incorrect, and they are just assumptions at this point.
Scarab has two 02 sensors. See pictures to back up my piss poor information. In the South or in Salt water conditions, the silver Catalytics have been corroding internally and leaking. BRP has been replacing the Cats for people since the corrosion and leaks have been eating up O2 sensors over a short period of time. ***Please Note, the issues are with SILVER CATS, not the updated Black one used today.***
Ron, I noticed mine was cracked at the flange, Seems like Someone "MM" over tightened it at some point. Ill Follow up with a photo once this rain lets up and I can access the boat. How Can i go about getting it replaced with the new version since its damaged anyhow?
I was trying to avoid going back to them again...... Don't want to lose the boat for the season over something that's not a real issue or causing problems.
I missed almost the entire first summer with my brand new boat. June to end of August in the shopI'm surprised papa bear's boat is still having issues. This string alone would keep scarab jet boats off of my list of jet boats to consider purchasing. 5 or 6 bad sensors now! Boating season has started and will be over before I know it, it's way too short to have a non operational boat.
