swatski
- North Caldwell, NJ
EDIT: For some reason I was having trouble finding this particular thread by @ridinpropless when I was starting this one. Out of many, many threads, it may be one of the best:
https://jetboaters.net/threads/i-think-i-finally-quieted-my-yamaha.10022/
The 2016 240s w/"quiet cruise" are big improvement in sound proofing. But some areas are still left vulnerable and need to be addressed. For example, the fuel tank hatch/cover is a big resonator -- still untouched from the factory. Along with the fuel tank / engine compartment / ski locker walls fore and aft. Basically, same as in the old boats...
So, I decided to start chipping away at it, as time will allow. It is a nasty job -- my hands are encrusted with fiberglass shards, bleeding, after just first few hours on the project. Oh, well.
This time I'm trying my luck with RAAMat and, so far, loving it. I got the "Package #1" for starters and really like both products: the BXT II seems like a great alternative to Dynamat Extreme, and the Ensolite which is kind of unique -- very pliable and relatively easy to work with.
http://www.raamaudio.com/categories/Mat-and-Foam-Products/
Here is what I accomplished thus far.
Fuel tank hatch got a double treatment on the inside, fairly strait forward. That thing is heavy.
When I reinstalled it, the RAAMat layers made the hatch sound like a tomb (good!)
I also stuck a layer of BXT II and worked in several layers of Ensolite to encase the engine comp wall.
And the opposite (fore).
And the same with the aft wall of the ski locker - those were all very resonant (before the deadening treatment)
As a side note, the fuel tank cover is a heavy fiberglass/FRP slab, but plenty of wood under the floor on the sides... (something to think about when installing SeaDek -- need to really seal those snap holes or it could be a mess down the road)
To be continued...
To be continued...
