mattscheuerlein
Battery question here. I have a two Battery set up. I run two amps off the start Battery till it starts to die, then I click it over to parrallel. Question is, should I just run the switch on parrallel from the start. Am I straining the first Battery, it seems to only last a few hours where it used to run a lot longer. P.s. I also have not checked the water level yet.
