Bill D
- Prairieville, LA
- Limited S
@jeremy0011 - got my light today, can you kindly point me in the right direction for the required bushing?@jeremy0011 - I'm sure I can do it, where can I get the brass bushing needed?
No worries, I actually have a new TAP set from Christmas that I've only used once. . . . . .After pressing it in you will need to run the proper drill bit and 10-32 tap through it. The bushing is made for plastic parts and it will deform when pressed into aluminum but once taped it works perfectly.
Super late to the party.After pressing it in you will need to run the proper drill bit and 10-32 tap through it. The bushing is made for plastic parts and it will deform when pressed into aluminum but once taped it works perfectly.
Yes I have both ready to ship I'll send you a PM.Super late to the party.
Do you have any tow point adapters left? With or w/o the navisafe included.
Thanks
PM sentWow just saw this, what a mod. Would like to order the navisafe option. Please let me know how to pay.
Thanks
Is there anyone out there that could possibly machine a base like the above light (in attachment link in previous post) that would fit between the older towers with the hex bolts in the middle. This would help all of us out with older boats/towers....Trying to find something like this which would also work. The image is from a Titan sight no longer functional.
