Bearings...
Jason A. Bolt
I apologize in advance if it is already on here, but need to replace the bearings and seals on the shorelandr trailer. It is a 2018 holding my Yamaha FSH210. Does anyone know what the bearing sizes are?
FSH 210 Sport
Tranquility Base
Go to shore landers website and put in your trailers vin number and look up the parts. It’s a bit of a process but you can find the info there. I’m pretty sure the bearing sizes are listed in the manual as well.
I’ve bought parts from this store and the service was great. Trailer Parts Superstore - Official Site
When you replace the bearings and seals you should replace the wear sleeves as well. SHORELAND'R S.S. Spindle Wear Sleeve (3,500 lb. Axles) #4410089
This is the order I made from them if that helps.
adrianp89
Tampa Bay, FL
252SE
How do you know when it is time to replace them?
kbell413
If your hubs are getting warmer than usual when towing, it's time. Put your hand on the hub after driving a decent ways next time. If you can leave your hand on the hub, you're fine. If it's too hot to touch, you might want to replace them before you have a failure.
FSH 210 Sport
Tranquility Base
I look at the rollers themselves for discoloration/ bluing from over heat and pitting. If pitted it discolored replace.
Then give a close look at the races for scoring and or ridging. It’s also possible to see wavy like features in the races. Replace if you see these features.
Take the cleaned bearings and put them in their races and roll them around, they should roll smoothly without any gritty sensation. Replace if not silky smooth.
