    With a Maximum discount of 35% this is the highest discount you can get on these, so don't miss out!
Bilge Pump Thru-Hull Fitting
Is there a reason you are replacing the straight out type with a 45° one? Seems like it’s just down to a color choice from the ones you linked. I installed GemLux straight out stainless steel fittings when I added the second bilge pump.
