View attachment 38953 View attachment 38954 View attachment 38955 View attachment 38956
I finally got around to lubing my steering cables. This is a setup I have used on many rusted e-brake cables with excellent results. Same principle as a cable luber for a motorcycle. The lubes is made from:
-3' of 1/2" ID heater hose
-1ea 1/2" threaded valve stem (like a tire). The idea is to be able to thread into the hose.
- 3ea 5/8" hose clamps and
- 1ea 1/2" hose clamp.
- some synthetic motor or gear oil.
The idea is to attach the hose over the steering cable with the clamps, fill the hose with synthetic oil, thread in the valve stem, secure it with a clamp and then pressurize with a bicycle pump. The pressure forces the oil through the cable casing to lube the cable. I put a large rag at the cable exit under the helm to catch any oil that comes out the other end. I had trouble with the oil getting forces out the rubber flex fitting so had to put the small hose clamp on it. I left it on to keep water out of the cable. Cam.
