Fourjets
- wilmington N.C. 28412
- Other
- PWC
Pics of end result?
Do you love em or like them?
So I have not looked to hard but whats the process of getting the original drain plug out of the boats? Mine is a metal plug that doesn't really came out that I know of it just unscrews and sit in the hole still.
@Dsalverda could you give me the dimensions of the Electra? I cant seem to get anything from the vendor regarding its size. Want to make sure it will fit behind my articulating keel.You will not be disappointed with boatpluglight!! Instead of the vega go with the Electra. It has the drain like you want without removing the light/plug
I think you answered your own question right before you asked itThis light alone pulls ~ 11amps right? 133 watts/12 volts ~ 11 amps.
If I wire straight to the battery, what fuse size should I use inline?
That'll work. Just shine a light in the engine compartment and make sure you can see the backside of that area.Any idea where the best place to install the Dagon 5150 on a 2015 LTDS? I'm thinking right over these warning stickers? I just can't tell 100% where that leads to in the engine compartment.
