Dual battery charger advice
dalcini
Utica, Michigan
Hi folks,
First boat - purchased used last fall. I'm wet-slipping at a marina this summer and feel I need to install a battery charger. I've read many great posts from folks like @FSH 210 Sport and others on batts and chargers and want to check my plan before moving ahead.
Here's my general plan for a charger install:
The two FLA batteries that came with the boat (used) still seem healthy, reading 12.5-12.7v. I maintained them over the winter on a small Noco Genius at home.
Some questions I have:
  • Is it ok to go with the 7a Victrons to keep the cost down? Mininum time between boat use will be overnight so charge time is not much concern.
  • Someday when I'm ready to replace my FLA batteries, I'll probably go with FLA+AGM or AGM+AGM. Does this change the plan for the Victron model at all? (my guess is no).
Any additional comments/advice welcome.
Go with the 25A IP67’s… they are worth the money, keep in mind you need 10-13% of the Ah rating of a lead acid battery to properly charge it. The new IP 67’s are highly adjustable from 3A to 25A, having used the 10A or 25A model I would not have any other battery charger. As a fyi, I shared several emails with Interstates tech dept and I was told in writing that their AGM batteries can be charged at 25A as long as voltage does not exceed 14.4 volts.
