Engine Code 1-9
gslooper
My port engine on my AR230 HO twin engine light flashed code 1 9. Anyone know what this code is and the fix?
Engine light codes
above is a link for the flashing engine light codes, 19 is incorrect voltage so maybe you have a battery issue!
I suggest you put this into your other thread with the dropping engine rpm…it will help folks like @Acard7 and others help to troubleshoot your issue.
This code was thrown on the opposite engine much later.
I will add it to the other as it may be related.
Thanks
