Finally broke her in, now upgrades and build
jocolo21
252SE
2 × JL Audio XD700/5v2:5 Ch. Class D System Amplifier 700 W
1 × JL Audio XD800/8v2: 8 Ch. Class D Full-Range Amplifier 800 W
1pr × JL Audio M650-CCX-SG-TB: 6.5-inch (165 mm) Cockpit Coaxial System Titanium Sport Grilles
3pr × JL Audio M3-650X-S-Gm-i - M3 6.5" Marine Coaxial Speakers (pair) - LED Gunmetal Sport Grilles
2pr × JL Audio 8.8-Inch M6 ETXv3 Tower Speakers, RGB LED, Gunmetal & Titanium, Sport Grille - SKU: M6-880ETXv3-Sb-S-GmTi-i
Wet Sounds 4 Band EQ w/ 3 zone control, talk back mic and AUX input
1 WS 12' bazooka
1 ws free air sub
1 × AudioControl LC2i 2 Channel Line Out Converter with Accubass and Subwoofer Control ( to convert speaker wire to rca)
jocolo21
252SE
So my Conex was lowering my radio vokume whenever it wanted by itself, so i decided to bypass it and installed Fusion MS-SRX400 ApoMarine Entertainment System with MS-ERX400 Ethernet Wired Remote.20210920_125901.jpg20210920_140456.jpg20210920_150912.jpg20210920_150429.jpg20210920_150915.jpg20210920_173108.jpg20210920_173221.jpgllo
1WetBoat
Tampa
Nice, I'm guessing you didn't use the cell phone holder? Are you concerned with the knob on the remote unit rusting out like the older boats used to do with it being on the swim deck area?
jocolo21
252SE
There is no knobs on the 252 just buttoms but a couple weeks ago it started lowering the volumen itself it was annoing, someone porte the same on a different page. The knob on .y old 2019 never rusted.
jocolo21
252SE
The phone holder broke the screws are glued.
1WetBoat
Tampa
That is interesting because I just ran into a similar issue but with the panel to the left of the screen. The one with the cup holder and where the start buttons are that folds over the console. I noticed the bottom loose and when i looked, the screws are also glued and that is what gave way. I used some 3m double sided tape to fix the issue.
Surprisingly for the AR that piece is $1k from Yamaha. Have no idea why its that expensive, its just a piece of plastic for the most part.
jocolo21
252SE
Yes glued screws, if you go to tight it’ll be broken
adrianp89
Tampa Bay, FL
252SE
Hmm this is tempting. I have been having noise/signal issues coming off from the factory. I have a AudioControl Matrix to put in place. If that fails I may go this route.
jocolo21
252SE
I used an audio contral lc1 which cleans and increases the voltage, works great but the issue was with the connex
adrianp89
Tampa Bay, FL
252SE
You shouldn't need the LC1 with the Fusion.
jocolo21
252SE
I dont , i said i used with the connext, the fusion puts out 5 volts, no line driver needed. so far i like the fusion the remote is very eay to connect via ethernet cable
jocolo21
252SE
Repowered the 4 jl8.8 cans with a Wrt Soumd SDK2 @2HOM which will feed 320wts to each of the cans. Dony worry gains were set at 250watts using a multimeter. V= Square root of WATTS X OHMS. But since each can hamdles 250 w.....v=sq root of 250x2. Did the same to the jl700/5 poeering 8 jl m3 @90 watts each and the 2 subs @ 2ohms = 300w x1. So far soumds amazing.
adrianp89
Tampa Bay, FL
252SE
What made you go with the riser?
jocolo21
252SE
Boredom lol, i figured it couldnt hurt so why not, i do lots of boating in the ocean, i can see how those can make their way into the bilge....by the way i tried the self bailer on Sunday, a bit rough at the lake the pump never kicked in, and not a drip of water when i retreived the boat. I dod buy the plug for leaving the boat for extended in the water
AZMark
Phoenix, AZ
Where did you get the self bailer? Never seen those before.
Do you think it lets water out while you’re underway on plane? Or does your boat just not leak at all now with the riser?
