steelhorse454
- Cape Carteret, N.C.
So, I boat in Salt and flush my boat every time out including using Salt Away. Problem is, I can't get fresh water to flow out of the 3 pissers due to low water pressure. I changed to a bigger diameter hose, no change. Shorter hose/ different location, no go. Water pressure here at the NC coast sucks.
I've seen running weed eater line from outside to inside mentioned, but does that really work ? I really want fresh water running through upon flushing.
I check the 3 streams of water every time out and they look good, but I know salt must be building up.
Any suggestions ?
Thanks.
Any suggestions ?
Thanks.
