Frozen wake tower bolts
Guy in a Boat
I have a 2012 242 with the forward swept tower that is exterior mounted. Has anyone had issues with the rear
bolts being froze and if so how did you fix it. I would like to be able to drop mine and not use the tractor to put it in the shop everytime.
Soak the bolts and nuts with Kroil, in my experience the best penetrating oil you can get.
Soak them with penetration oil and hit them lightly with an impact. The hammering affect should break them loose.
I would add, if it is possible, back up the other side with a wrench when you start to put a lot of force on them. Try soaking the bolts each day for a week before you hit them with a lot of force. As @Babin Farms says, hit them LIGHTLY with an impact.
Seeing this post makes me think I should add removing my T top mounting bolts and anti seize them over the winter.
