Jeff L24
- 195S
I've read several posts about pulling the jet pump to remove a piece of wood that is wedged in my impeller blade. It sounds like this may be quicker than messing with it using a long screwdriver through the intake grate.
My question is for those people who have pulled their jet pump to clear an obstruction. Do you use the liquid gasket maker (Loctite 518/Permatex 51813) each time you pull it? If this is something I may need to do repeatedly in one season (hopefully not), is the gasket maker needed each time, or perhaps just at the end of the season, or maybe some of you don't even use it at all? Thanks.
