Has anyone done a 2022 Yamaha AR195 Ribbon delete?
Hbjrico
AR195
Has anyone done a ribbon delete on a 2022 AR195? I can only find the ring for 2913-2017 models for some reason
Did you try using this sites search engine? I’m sure there are threads with the info you are looking for here..
Been searching for a couple hours. There a lot of info on models 2017 and older the ribbon was right on the throttle. Looks like newer models have in on the manifolds
That is correct.. RIVA makes a ribbon delete kit for both the TR-1 and the 1.8L engines..
I'm assuming this is the kit for the 195. How long would this install take and how involved?
I'm sure YouTube has some videos on it. However I'm not sure of the actual benefit from these kits. Maybe a little extra RPM?
First you need a service manual.
You’re going to have to pull the intake manifold off to remove the ribbon ….
I’d guess a full day on a Saturday will get it done.
