Help identifying a part
RockShawn
As I have been mounting new electronics, I noticed this coming off the wiring harness but have no clue what it is or does. It almost looks added on since the shrink wrap is kinda crappy. Can someone help me identify it? It has what looks like 4 vents on the front and the front cap rotates where the vents are either open or closed.tempImagebXNasf.jpg
I think @BlueBulls is correct, that is the alarm horn. Low fuel, high temp etc….
Thank you guys. It is just such a weird looking part and not all that professionally done. so far it’s the only thing i couldn’t figure out.
And I won’t ask about the “possible” nema connection off the harness to the connext LOL. I don’t know what that Duetch connector is for but man i really wanna get gauges to show on my second 9”
There is only one person that I know of that got the connext screen stuff to show on a NEMA platform.. it’s something a lot of people would like to have.. its not like Yamaha’s other stuff.
The beeper top rotates the vents, which are meant to reduce the sound. I wrapped mine in insulation material to mute the loud and persistent beep. They should have included a water alarm in the bilge that beeps like that annoying one. Every season, about 6 to 12 members report engine bay flooding. How many don’t report it?
I’m pretty used to watching the bilge constantly. The 1993 Tracker I was on leaked like crazy and the bilge pump was not automatic so was constantly turning it on and off. The previous owner of this Fsh told me the bilge pump was automatic, even with the batteries turned off which sounded a little suspect until I washed the boat. Batteries were in off position and the bilge did seem to pump as i was washing every so often.
But to be clear on this, cause I’ve seen several posts about it, the bilge rocker switch should always be on when operating? Or is it truly automatic without activating the rocker switch? I really hate that that is confusing, but he didn’t really explain to me which position to put the rocker switch in, whether that’s the up position or down position where the light is actually on. I’m thinking that the down position with the light on is the manual activation. But would like to be sure before getting it on the water. I’ve only had the boat for a week and a half and haven’t put it on the water myself yet. I did do a late test with the previous owner before purchasing, and he never touched the rocker switch for the bilge pump
Your bilge pump has an automatic and manual run. The auto side is fed from a fuse in the battery box area, on my boat there are three separate fuse holders on the bulk head, I know one is for the bilge pump auto side, and the other is the accessory main fuse and I can’t remember at the moment what the other one is..
So, as you found out, with the hull plugs in, if you had water to the engine bay the bilge pump will turn on automatically to pump the water out and then turn itself off, there is an internal float or sensor. The rocker switch on the dash is the manual side of the pump and has its own circuit breaker. This switch should be left in the OFF position unless you suspect the auto side is not working, then turn it on and see if any waster comes out, if not turn it off.
These other posts you’ve seen about leaving the switch on is for the older boats. Up until 2018 I think you had to leave the battery switch on to power the bilge pump auto side .. but starting I think in 2019 the auto side of the bilge pump is wired directly to the battery.
Now then, a brief bit on water intrusion. First, you can totally have a dry bilge on these boats, but it takes a small amount of work. The biggest contributor to water intrusion is the clean out tray. You need to put a bead of silicone around the perimeter of the tray after it’s installed, do not glue it down! The next thing is to get a mechanical hatch riser from Jet Boat Pilot. Our boats have the two channels, one on either side of the clean out tray for water to drain out of, so the drain in the tray can be eliminated if you want, that is what I did. Then get a few O rings from @Spooky pantz to put in the metal groove at the bottom of your clean out plug to eliminate any water coming in there.
That contribution by @TeeNGee is arguably one of the most useful finds anyone has made regarding these boats and water intrusion.
Next read this thread
The other thing you should definitely be looking to replace is the live well drain scupper, I think both of your deck drains come out relatively high above the water line. On my boat, both the OEM deck drains and the OEM live well drain come out right or below the water line, and these fittings are plastic and can break and your boat can sink, so a good number of use have changed those out to stainless steel.
Again, you can have a boat that will have no water come out at the end of the day and your bilge pump will not run while you’re out on the water.
