dzeppos
- Coto de caza, CA
- Limited S
I have a 2016 Yamaha 242 S that I purchased brand new, and over eight great boating seasons, now has almost 400 hours .
The boat has mostly been trouble free since inception (other a few minor adjustments).
Finally, on our last day of a week long lake boating trip, we heard an awful cavitation sound once we hit the throttles coming from the Starboard engine.
Our initial reaction was that had been sucked into the impeller. After pulling the boat out, we realized that there wasn't anything in the impeller, but an awful vibration from the starboard engine from inside the engine compartment.
The boat mechanic I use, (who's been incredible and has been servicing my boat since I purchased it) realized that it was a bearing issue at the jet pump (on end of the cone) - and that two bearings were bad.
The damage from the vibration also caused some damage to the housing bearings inside the boat (inside the engine bay)
But it was the actual housing - the unit bolted on the hull that was loose. It seems like it wasn't done correctly from the factory almost 8 years ago, and it loosened over time, which caused the vibration which in turn damaged the bearings.
The worst part is that the labor required taking off the catalytic converter (Thank you California and the unnecessary and over the top environmental requirements) to get to the bottom of the bilge to move the engine so that they drive shafts and bearing/housings could be replaced.
I’m almost fortunate that took 7+ years to have this issue come about, which was clearly done wrong from the factory. Unfortunately, the cost in labor and parts was significant. He also checked the housing bearing bolts on the Port engine (which was running fine), and found that the housing bearing bolts were also somewhat loose. However, there was no damage and he tightened those bolts as well.
The issue is that it wasn’t that the bearings went bad, but that the loosening over time starts of the housing bearing to the hull caused the boat to cavitate and damage the bearings (on both sides of the jet pump unit).
I offer this post because my mechanic who's been working on Yamaha boats for 20+ years and had never seen this issue (from the housing being loose). He says there’s no way anyone could have tampered with that and it was improperly put together from the factor. I don’t know if anyone else ever encountered this issue with the jet pump drive unit (as connected to the engine). There’s nothing in the manual that says this housing bearing unit needs to be tightened or adjusted/inspected.
On the upside, the Starboard engine is now very quite at idle. Its never been this quiet. At 5500 rpms, its much quieter as well. My Port engine is somewhat louder (typical sound since I bought the boat) but well within the norm.
In addition to replacing the air filters and getting the housing exactly aligned, we test ran the boat out in the ocean today and had incredible performance on all rpm levels. It seems like my boat runs better and quieter than it did when it was new.
Happy to discuss or offer additional comments, but despite the cost and being out of service for 7 weeks, the boat runs better than new.
And if you need a referral, Dan is the best mechanic out there in Southern California. Just let me know,
